August 4, 2017 - Burleson, Texas, USA. CAD-MANUFACTURING SOLUTIONS, INC. announces the release of the new CMS IntelliCAD 8.4 Premium Edition (PE) 2D & 3D Compatible CAD Software.
CMS IntelliCAD 8.4 PE is a major release that boosts performance during screen redraw and while snapping in files with underlays. Running IntelliCAD on 4K monitors and switching between monitors with high resolutions is now supported and more...
New features can be found throughout IntelliCAD 8.4. Create entities with the new Multileader, Quick Leader, and Break Line commands. Add styles using the new Multileader Styles Manager and Multiline Style commands. Select entities using the new Select Similar and Get Selection commands. Explode entities with more precision according to entity type using the new Explode Text and Explode Attributes commands. Add more formatting to text using the in-place Multiline Editor and line spacing, lists, and paragraph justification. Add automatic numbering to text, multiline text, multileaders, or block attributes using the new Auto Number command. Get more information about your drawings using the new Drawing Properties command.
Another new feature is found in the updated Customize command which allows users to customize the user interface with less effort and share custom user interface settings easily between files and computers. You can drag-and-drop settings to customize menus; the ribbon, application button, and quick access toolbar (for IntelliCAD versions that support a ribbon); toolbars; keyboard shortcuts; and aliases.
In focus
• Support for 4K monitors
• Boost in performance during screen redraw
• Improved performance for overlay snapping
• Edit your user interface with new CUSTOMIZE
• Create and edit MLeaders and MLeader styles
• Attach and explode IFC underlays
• Many new Express Commands:
- Select Similar
- Get Selection
- Burst
- Break Line
- Explode Text
- QLeader
- Automatic Numbering and more!
CMS IntelliCAD 8.4 Premium Edition has been released as Perpetual Standalone 64-Bit version. The Premium CLOUD version, provided through application streaming for 64-bit systems, will be available soon.
